Hi All, Very new to both FreeNAS and forums, but have a bit a of solitary linux exp.
Love nothing more than configuring stuff, and playing with hardware.
fav stuff:
LINUX
XEN
zoneminder
bitcoin
nagios
owncloud
asterisk
mythtv
XBMC
Pet hates:
windows
and electric bills!
Stumbled on FreeNAS and thought I'd give it a go
Still putting my first box together out of old bit and debugging its many problems. Found FreeNAS a Really eased the transition to BSD and ZFS. from linux and ext
I have collected up discs out of all my boxes and ended up with 5*2TB Reds in Z1 as main NFS, ISCSI, TFTP, media server vol. and no sure if its a great idea but a 3*2TB purple, suv drives in a 6TB stripe for CCTV and live Tv (myth), not so very important. I have a 8TB SeaBackPLUS USB3 EXTERNAL thing that I have encrypted ZFS and have been trying to replicate my main 5*2TB Z1 to nightly.
Very Very please to have firefox sync working with owncloud in a jail ....against all probability ( think they seem to have stopped supporting it ages ago) Not managed since OC8.1. For anyone interested..
remove .mozilla
Install FF28 from http://ftp.mozilla.org/pub/firefox/releases/ on desktop
copy mozilla sync 1.4 (only official support for OC6) from apps.owncloud site to your .............../jails/customplugin_1/usr/pbi/owncloud-amd64/www/owncloud/apps/ and extract.
sync FF28 using own server and your oc id , sync url..., and password
then used apt to update to latest FF
to my amazement.....
IT WORKS!
passwords/books/history/etc
will try to sync android next...not so easy if I remember
no idea FF for windows...DONT CARE ;-)
I have had one or two CRC errors (nothing in smarts) which appear to have stopped now I have swapped leads, power cables, pci-e cards about a bit...
My main mystery at the moment is why after replication (reports up to date) , my encypt 8TB vol appears EMPTY! first time was a heart stopper. If detached and re imported with key and pass all files, snaps etc are present and correct. But until I reimport the volume my logs are filled with
Oct 30 02:23:15 nas collectd[16336]: statvfs(/mnt/backup/jails/.warden-template-pluginjail) failed: No such file or directory
Oct 30 02:23:15 nas collectd[16336]: statvfs(/mnt/backup/jails/.warden-template-standard) failed: No such file or directory
Oct 30 02:23:15 nas collectd[16336]: statvfs(/mnt/backup/jails/customplugin_1) failed: No such file or directory
etc etc etc
cant find anything else in any logs?
just a mystery of the empty volume...?
The files seem to disappear a few minutess after replication?
The volume is there and showing mounted,
ONLY PROBLEM ! no files in an empty directory tree , until I export and import the volume.
is there a way to increase to verbose on logs as I can find anything much?
Reading more online I'm loosing faith in my choice of Z1 and its ability to rebuild.. after several years of living with 3*2TB and a separate 3*1TB all ext Linux md stripe only, I was looking for a bit of security.
Hoping some here might be able to offer some pointers:
are 5*2TB RED's in Z1 anywhere near a reliable solution?
what happens to Purple AV drives when offered upto the ZFS/FREENAS Gods and a stripe?
anyone know why a vol might be an empty Dir tree till reattached?
Brgds
Florence
FreeNAS-9.10.1-U2
AMD FX4130 Quad-Core Processor
GIGABYTE 990FX
Memory 16081M
5*2TB RED Z1, 3*2TB Purple stripe, 1* 8TB USB3
fav stuff:
LINUX
XEN
zoneminder
bitcoin
nagios
owncloud
asterisk
mythtv
XBMC
Pet hates:
windows
and electric bills!
remove .mozilla
IT WORKS!
etc etc etc
zpool status and zfs list both look normal and all online ONLY PROBLEM ! no files in an empty directory tree , until I export and import the volume.
Brgds
Florence
FreeNAS-9.10.1-U2
GIGABYTE 990FX
Memory 16081M
