I have been having issues with CrashPlan constantly downloading a new version and trying to install it.
I explained the issue in this Post as well but no one confirmed it was the same issue so I am making its own thread as it disconnected from CrashPlan again (I was able to get it connected but I got to think this is not healthy).
When I look at the History tab in the GUI I get the following (every 20 min or so):
Downloading a new version of CrashPlan.
CrashPlan has downloaded an update and will restart momentarily to apply the update.
Installing update - version 1435813200470
Upgrade failed - version 1435813200470
It then repeats every 20 - 30 minutes. (See screen shot below).
I have 4.7 installed.
For a starter can anyone point me in the direction where I would find the error log for why the Upgrade failed for version 1435813200470?
ee /var/log/crashplan/engine_error.log
Produced the following
/etc/host.conf: line 2: bad command `hosts'
/etc/host.conf: line 3: bad command `dns'
/var/log/crashplan/engine_output.log
=====line 22 col 0 lines from top 22 ========================================== Java HotSpot(TM) Client VM warning: Can't detect initial thread stack location - find_vma failed [07.18.16 01:19:39.606 INFO main com.backup42.service.CPService] Locale changed to English [07.18.16 01:19:39.606 INFO main com.backup42.service.CPService] ******************************************************** [07.18.16 01:19:39.606 INFO main com.backup42.service.CPService] ******************************************************** [07.18.16 01:19:39.606 INFO main com.backup42.service.CPService] STARTED CrashPlanService [07.18.16 01:19:39.607 INFO main com.backup42.service.CPService] CPVERSION = 4.7.0 - 1435813200470 (2015-07-02T05:00:00:470+0000) - Build: 317 [07.18.16 01:19:39.607 INFO main com.backup42.service.CPService] LOCALE = English [07.18.16 01:19:39.607 INFO main com.backup42.service.CPService] ARGS = [] [07.18.16 01:19:39.607 INFO main com.backup42.service.CPService] ******************************************************** [07.18.16 01:19:39.858 INFO main com.backup42.service.CPService] Adding shutdown hook. [07.18.16 01:19:39.904 INFO main com.backup42.service.CPService] loadConfig, BEGIN Loading Configuration [07.18.16 01:19:39.930 INFO main com.backup42.service.CpsFolders] CpsFolders chmod successful. confPath=conf/ [07.18.16 01:19:39.930 INFO main com.backup42.service.CPService] BEGIN Copy Custom [07.18.16 01:19:39.930 INFO main com.backup42.service.CPService] Directories: [.Custom, custom, /repository/.Custom, /repository/.Custom, /repository/custom] [07.18.16 01:19:39.930 INFO main com.backup42.service.CPService] NOT waiting for custom skin to appear [07.18.16 01:19:39.930 INFO main com.backup42.service.CPService] NO customizations found. [07.18.16 01:19:39.930 INFO main com.backup42.service.CPService] END Copy Custom [07.18.16 01:19:39.931 INFO main backup42.common.config.AppConfig] Loading from default: , /usr/pbi/crashplan-amd64/share/crashplan/conf/default.service.xml [07.18.16 01:19:40.087 INFO main backup42.common.config.AppConfig] Loading from my xml file:, conf/my.service.xml [07.18.16 01:19:40.180 INFO main up42.common.config.ServiceConfig] ServiceConfig:: Loading ServiceConfig, newInstall=false, configVersion=8, configDateMs=1466037034691, installVersion=1435813200460, currentVersion=1435813200470 [07.18.16 01:19:40.181 INFO main up42.common.config.ServiceConfig] ServiceConfig:: OS = Linux [07.18.16 01:19:40.323 INFO main com.backup42.service.CPService] AuthorityLocation@986939266[ location=central.crashplan.com:443, hideAddress=false, isLocked=false ] [07.18.16 01:19:40.323 INFO main com.backup42.service.CPService] Checking Java memory heap max. [07.18.16 01:19:40.324 INFO main com.backup42.service.CPService] Previous Java memory max heap size was 2048 [07.18.16 01:19:40.325 INFO main com.backup42.service.CPService] END Loading Configuration jtux Loaded.
