nickt
- Feb 27, 2015
Hi all,
I've successfully got Crashplan installed as a plugin, and it's working very nicely, which is great. My only problem is that I can't get it to work in restricted hours (I have only 1 Mbps uplink to my ISP, so I want to restrict Crashplan to run out of hours, otherwise it kills the internet for everyone).
So I've tried to apply settings that should restrict backups to certain times - easily configured, but it doesn't actually seem to work. The backup just keeps running. I've tried pausing from the GUI (which works), but when I unpause, it runs immediately. I've tried restarting the jail, but it just starts immediately as soon as the jail comes back up.
Has anyone had this problem? Any thoughts?
For reference, in the GUI, Settings -> Backup -> Backup will run, there is an option to run "between specified times" only. Very easy to set up, and I can see the settings reflected in the relevant config file in the jail (
/usr/pbi/crashplan-amd64/share/crashplan/conf/my.service.xml):
Thanks in advance. Nick
<backupRunWindow> <runWindow always="false" days="SMTWHFS" endTimeOfDay="07:00" startTimeOfDay="00:05"/> </backupRunWindow>
