Crashplan doing nothing
philhu
Installed the plugin, try to start it, about 10 seconds after start, it stops
Where do you configure it? I do not see instructions for setting it up correctly.
Thanks
D
dlavigne
Guest
Anything in /var/log/messages when it fails to start?
What is the exact FreeNAS build version (from System -> Information)?
philhu
Build: FreeNAS-9.10-STABLE-201606270534 (dd17351)
The shell seems really slow too, just for crashplan, my others, plex, pytivo, bacula- are running fine
I installed as a package, so do not see why rc.conf is wrong, if it is
rc.conf:
root@crashplan_1:/usr/home/philhu # cat /etc/rc.conf
portmap_enable="NO"
sshd_enable="YES"
sendmail_enable="NO"
sendmail_submit_enable="NO"
sendmail_outbound_enable="NO"
sendmail_msp_queue_enable="NO"
hostname="crashplan_1"
devfs_enable="YES"
devfs_system_ruleset="devfsrules_common"
inet6_enable="YES"
ip6addrctl_enable="YES"
var/log/messages:
Jul 8 14:34:51 crashplan_1 newsyslog[81206]: logfile first created
Jul 8 14:34:51 crashplan_1 syslogd: kernel boot file is /boot/kernel/kernel
Jul 8 14:36:11 crashplan_1 syslogd: exiting on signal 15
Jul 8 14:36:15 crashplan_1 syslogd: kernel boot file is /boot/kernel/kernel
Jul 8 14:36:15 crashplan_1 root: /etc/rc: WARNING: $crashplan_enable is not set properly - see rc.conf(5).
Jul 8 22:33:29 crashplan_1 pkg: pkg upgraded: 1.6.4_1 -> 1.8.7
Jul 8 22:33:32 crashplan_1 pkg: nano-2.4.3 installed
Jul 8 22:34:07 crashplan_1 syslogd: exiting on signal 15
Jul 8 22:34:11 crashplan_1 syslogd: kernel boot file is /boot/kernel/kernel
Jul 8 22:34:11 crashplan_1 root: /etc/rc: WARNING: $crashplan_enable is not set properly - see rc.conf(5).
SO MY QUESTIONS:
Why did a standard install not set rc.conf
Does someone have an rc.conf for crashplan I can see?
How do I set the user/password and files to backup for the freenas system on Crashplan?
philhu
got a bit further.......
added 'crashplan_enable="YES"' to rc.conf
Now upon starting, it says as I start it.:
# service crashplan start
WARNING: No shebang in /usr/bin/cpuset
Starting Crashplan engine...Using standard setup
OK
ELF binary type "0" not known
D
dlavigne
Guest
Did you install this using Plugins or did you pkg add it in a jail?
Was your original installation on 9.10 or did you upgrade from 9.3? If an upgrade, did you have existing plugins/jails when you upgraded to 9.10?
That error sounds like an ABI issue...
philhu
It was installed as a plugin on an original 9.10 new system
After reading, i think with Crashplan being so fragile, i might try an install in a jail with mounted storage to backup. Like a centos jail
