Hi all, I did do a search prior to posting, and I found a thread that seems to be a similar situation where the user experienced a crash during a delete operation: https://forums.freenas.org/index.ph...-kernel-mode-error-while-mounting-pool.16926/
It's old however and not sure if still relevant. My crash occurs at a different location, as well.
I ran rm -rf on a fairly large directory tree and a few minutes later, lost all network connectivity to the box. I plugged a monitor into it and saw the crash message on screen. Unfortunately I didn't have a keyboard plugged in at the time, and plugging in one at that point got no results, so I had no choice but to reboot, at which point the error returned when the system attempted to mount.
Sorry about taking a picture of a monitor. :p I do see reference to serial console in the manual, but unless it's turned on by default, I don't think I'll be able to use it.
Taking some time to transcribe some of the output:
Fatal trap 12: page fault while in kernel mode
fault code: supervisor read, page not present
current process: 321 (txg_thread_enter)
Stopped at: range_tree_vacate+0x24
I also snapped the bt output, if that's helpful here:
It seems to me from searching that simply doing a fresh install (in my case, setting up a new USB stick) and then importing the pool should do it. If that's the case I'll gladly do so.
My main goal is to rescue the data. Ironically, I was deleting some backups from the NAS, but I still had some that hadn't been restored yet.
