CouchPotato put.io Integration
1nv1n
I've setup CouchPotato on my FreeNAS server earlier this week with the goal of having it download through put.io
I've got it configured so that it's able to search correctly, snatch correctly & upload correctly to put.io (I've set it up to go to a folder called 'CouchPotato') So put.io downloads & then puts the file in that folder. What I haven't been able to get CouchPotato to do, is to be able to download that file from put.io
I think the problem is with the Callback URL. This needs to be defined on the Settings in put.io's web interface & the same URL needs to be on CouchPotato's settings.
What I've configured it as:
CouchPotato: Callback Host: <My IP Address>
put.io: Callback URL: <http://My IP Address>
I've checked the 'Download' option on CouchPotato's put.io Settings. And ensured that the Download Directory is valid.
Looking at the source code, it seems that CouchPotato automatically adds the 'http://' so I've left that out of the 'Callback Host' setting.
I've ensured that port 5050 is forwarded correctly making CouchPotato accessible from outside my local network.
There's a couple of threads on the CouchPotato forums on this, but no solution. And I haven't been able to post there because the board never sends me the activation e-mail. I've already e-mailed the administrator to request access, but no reply yet.
If anyone's got it configured, can you share your settings?
1nv1n
No, I haven't yet. It's been a few days since I've looked at it - but I'll try to save some logs tonight. Have you any suggestions?
D
dlavigne
Guest
Nope, just wondering if you were able to find a solution.
