Correct way to replace encrypted drive.
Lansing123
Hello
I have a pool that is encrypted, i accidentaly used replace drive while the pool was encrypted, to my suprise it accepted it and started resilvering. I then unlucked the pool. Did i screw up? Or will everything work as normal? The reason I'm asking is because i have seen other posts mention that you need to rekey the pool or you risk losing it. I use a passphrase, do i need to set it again after resilvering?
Best regards.
