Hello, I am trying to create a container using the GUI in TrueNAS Scale and I'm running into a lot of trouble. The docker-compose syntax is:
How can I add the command argument through the GUI? I've tried adding the array with brackets and just a string of text to the COMMAND argument in the GUI but the instance fails to start when there is anything in the command field.
Thank you
Nprobe:
restart: always
container_name: nprobe
cpu_shares: 128
network_mode: host
environment:
- PUID=1002
- PGID=1002
- TZ=America/New_York
- HOST_OS=Linux
volumes:
- '/dockerpool/nprobe/nprobe.license:/etc/nprobe.license'
image: ntop/nprobe:latest
command: ["-i", "none", "-n", "none", "-3", "2055", "-T", "@NTOPNG@", "--zmq", "tcp://*:5556", "-b", "1"]
depends_on:
- ntopngHow can I add the command argument through the GUI? I've tried adding the array with brackets and just a string of text to the COMMAND argument in the GUI but the instance fails to start when there is anything in the command field.
Thank you
