OK, so here's the state of affairs:
- I have install images for 10.0.2 and 10.0.5.
- I could verify the 10.0.5 image by downloading the checksum file via archive.org.
- Only the 10.0.2 successfully does a fresh install.
- 10.0.5 won't do a fresh install (hitting <Enter> on "Install" does nothing).
- An upgrade installation of 10.0.5 with new boot environment seems to work but afterwards I cannot logon in the UI, anymore.
So - some rough edges, 10.0.2 gives a good impression of what the UI was capable of. Runs fine in a VM on FreeNAS 11.3 with virtio devices.
If you want a copy to toy with:
Nextcloud - Hausen Family Cloud Home
cloud.hausen.com
I take no responsibility for anything if you run this software. Both versions were provided by some friendly fellow forumers. Thanks, guys.
Kind regards,
Patrick
P.S. I still remember running Corral quite fondly. Never noticed that the 10.0.5 install iso would not install. But then I started with the early betas and upgraded everything from there up to 10.0.5.
