ajh
- Jul 24, 2023
The upgrade appeared to have gone smoothly, but something in the realm of AAA is clearly wrong. Is there a 'fix permissions' script/check somewhere? When I try to install an application they get stuck at Deploying, never create the container, and no logs are generated. The only hint of what is up is the error when I try to bring up a shell into the container.
WARNING: Your user does not have sudo privileges so /usr/local/bin/k3s command will run
on your behalf. This might cause permission issues.
error: unable to upgrade connection: container not found ("plex")
Nothing I can see beyond this, seems like a validation bug when upgrading not correcting something or adapting something correctly.
