Core and Scale I219-V
nstallons
I currently can't get Core or Scale to work on an older second-hand mobo I have. It is an Asus CODE IX Maximus using a I219-V. I see comments all over and it seems like some people believe it's supported in the more recent versions but I for the life of me can't find anywhere that would list if it's compatible or not.
I see that at least an RC of SCALE was compatible (for one user)...
I see that plenty of posts indicate the 217, 218 and 219-V are expected to not be great on FreeBSD.
nstallons
Right, I see the same just looking to see if there was an official wording I checked the FreeBSD list and it seems supported. But alas no luck. Currently, I am running through a CabelMatters USB to RJ45 adapter I use for my Pi's. I guess I shall just order an intel nic, was hoping I could hold off on that. Any recommendations for the best bang for the buck card? Seems like an Intel I210 would be the best card for sub-100.
