SOLVED Copy/Move dataset
djidji perroto
I have no successful snapshots (output of step 2 above is empty)
I probably didn't explain clearly, I don't need incremental snaps, I'm just migrating data from one pool to another, so I can lifecycle the drives.
Is there a way to delete the 'unsuccessful' snapshot that's keeping the dataset busy?
A reboot of the target system may be needed as you have possibly got a stuck transaction which will never complete since your session was cut.
Maybe you could destroy the dataset (if it lets you do that with a -f).
In any case, if there are no snapshots already across, you'll start from scratch.
