I don't know what the GUI's behavior is. You can try just adding the new device and checking the result with zpool status. If that doesn't work as intended, remove both SLOG devices and add them both at once.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
