- Feb 6, 2014
Picking up from here:
https://forums.freenas.org/index.php?threads/iscsi-drops-connection.62272/page-2#post-490153
Admission: Ye Olde Write Throttle could do that.
Counterpoint: The new one will eventually throttle your pool down to 10 IOPS if you're running right up against the
Sidebar: If you know that you're going to have a huge burst of write activity, the array should be prepared for it - whether that be a sufficiently-large write cache (or not-a-write-cache SLOG) or being made of sufficiently quantity/quality devices depending on I/O profile.
Conclusion: I made a new thread in Off-Topic so we can quit hijacking this one. ;) (You are here.)
Flip side: blowing out write caches don't typically freeze all I/O and cause your storage array to drop offline.
dirty_data_max value, but I've yet to see that happen in real-world use.Sidebar: If you know that you're going to have a huge burst of write activity, the array should be prepared for it - whether that be a sufficiently-large write cache (or not-a-write-cache SLOG) or being made of sufficiently quantity/quality devices depending on I/O profile.
