meisnick
- Jul 20, 2016
I am running 9.10 Stable
ASRock E3C224-4L latest bios
i3-4170
16gb DDR3 1600 ECC memory
2 Dell Perc H200 Cards flashed to Avago p20 IT firware
14 WD red 3TB drives
The system was running fine up to about a week ago where it dropped several hard drives
I rebuilt the Raidz3 array 2 times and pulled the erroring drives and ran a full destructive surface scan and found no errors with the disks.
I ran a weekly backup to a second array and towards the end of the backup the web interface crashed files stopped copying and the system dropped its network connection while IPMI continued to work on next IP address
I rebooted the system everything came back up finished copy but again it failed the same way near the last files
I pulled several of the disks and ran SMART and surface checks in another machine which all came back good
Rebuilt the array on a fresh install of 9.10 array failed several drives suffered Error 22 and timed out
different drives every attempt
Destroyed the array ran DBAN across all drives to reset everything back to factory fresh
Built the array again and it was successful write errors immediately started happening on multiple drives from both Dell cards
Shut system down and ran memtest86 and viewed system diagnostics nothing is wrong
I'mat a loss I've been running some form of freenas since version 7 and I've never had a system spin into instability like this
after 23 mins of up time
i3-4170
