B3yondBlu
- Nov 16, 2016
Since about December of last year I've had constant hard drive failures.  I have replaced the drive about 5 times now since then, brand new drive each time.  The kicker is its always been the same slot drive that needs to be replace.  Every time I swap it out with a new one it holds for about 2 weeks then fails.  First I thought it might have been the SAS controller on the motherboard.  So I switch it to another SAS controller since the motherboard has 2 controllers.  After a few days again I had the same failure with the same drive.  Next I tired changing power supply output cable.  That held for a few days and again it failed again with the same errors and drive.  Really not sure where to go next or maybe I've overlooked something. Its just too much of coincidence of the same drive to fail over and over again within a short period of time.
Reoccurring error
My System
OS: FreeNAS 9.10.1
CPU: Intel Xeon E3-1231v3
Mobo: Asrock E3C224D4I-14S
Memory: 32 GB DDR3 ECC
Storage: 10x Seagate Ironwolf
			Reoccurring error
> (da3:mps0:0:9:0): WRITE(10). CDB: 2a 00 36 55 a1 58 00 00 b0 00 > (da3:mps0:0:9:0): CAM status: SCSI Status Error > (da3:mps0:0:9:0): SCSI status: Check Condition > (da3:mps0:0:9:0): SCSI sense: UNIT ATTENTION asc:29,0 (Power on, > reset, or bus device reset occurred) > (da3:mps0:0:9:0): Retrying command (per sense data)
My System
OS: FreeNAS 9.10.1
