I have installed Truenas, yesterday I saw a error log in the server screen and i cant access to the web login and the console options so I decided restart forced the server. After boot I checked the logs and i found into the middlewared.log the following alert:
I am running the last version of TRUENAS (TrueNAS-12.0-U3) after that I apply the update I got some constant reboots and access to shared files generate permission errors. Thanks you for the support
File "/usr/local/lib/collectd_pyplugins/disktemp.py", line 43, in init
    with Client() as c:
  File "/usr/local/lib/python3.8/site-packages/middlewared/client/client.py", line 282, in __init__
    self._ws.connect()
  File "/usr/local/lib/python3.8/site-packages/middlewared/client/client.py", line 124, in connect
    rv = super(WSClient, self).connect()
  File "/usr/local/lib/python3.8/site-packages/ws4py/client/__init__.py", line 216, in connect
    self.sock.connect(self.bind_addr)
ConnectionRefusedError: [Errno 61] Connection refused
