- What is the latest "Release" for Jails, 11.2-RELEASE-p5 or 11.2-RELEASE(fetched)? If I try to edit a jail's release to the fetched version I get an error, so everything seems to be stuck on p5. I'm not sure what that is but I assume it's an updated version of the 11.2-RELEASE.
- How will I know if a Jail Release newer than 11.2-RELEASE-p5 becomes available?
- How will I know if a Plugin has a newer version available?
- What version is the Plex Plugin? Mine says N/A for the version.
- What exactly is the "Update" feature for Jails supposed to do? Does it update a Plugin? Or does it update a Release? Does it do anything with the pkg manager?
- Why does it instantly say successful if you try to Update while a Jail is already running? The wiki says to shut the Jail down first, if you do this then there is a short delay before again saying successful. It seems that in both cases the update is not actually successful.
- What is the point of showing Installed Plugins on one screen, and then Jails on another? It is silly that you have to go to one screen to open up the Management link for Plugins, but then have to go to the Jails screen in order to Update the Plugin. Seems like there should only be a single view for just Jails, with an option to filter and show Plugins only.
