ramitche
- May 31, 2011
Just 'upgraded' to FreeNAS 8 and am wondering if there are proven steps to configure a fairly typical wireless connection using DHCP and WPA-PSK security on an ath0 interface.
I have a found a few 'how-to's' on this, mostly for FreeBSD, however none appear to be the definitive solution. I have worked around the read-only root partition (manual re-mount), however some of the other configuration files seem to get re-initialized after a reboot (/etc/rc.conf and /etc/wpa_supplicant.conf).![Confused :confused: :confused:](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
this is one of the how-to's i found: http://jasonk2600.wordpress.com/2010/01/09/quickie-howto-wireless-access-in-freebsd-8/
Any help would be appreciated.
