Ok, I'm stumped, loaded FreeNAS-8r7350-amd64 and went in to change the host address from DHCP to Static. When I do that I can no longer access the box via the web interface.
After resetting to factory defaults and looking around, i found under system that the webgui IP address can be changed. However, the drop down only provides the current DHCP served addresses, there's no way to manually enter an address.
I'm sure there must be a simple way to do this (change from DHCP to Static), and i've used FreeNAS versions for years (just not FreeNAS 8); just can't seem to find it. Any help would be appreciated.
