mihies
- Jan 6, 2022
Hi guys,
I'm running alpine as virtual machine and within it the docker. I'd like to use mounted ZFS datasets for docker volumes.
On TrueNAS (Cobia) side:
I have a local group docker_share consisting with root and my username members.
I'd create a dataset, set its ACL Mode to SMB/NFS4, set owner user to root and group to docker_share, set NFS4 permissions to user@, group@ and everyone@ to Full Control.
Then I'd enable NFS share for said dataset.
On Alpine side:
I'd mount NFS share from above (fstab:
It almost works except when I start a docker container using this volume it gets "Permission denied" here and there.
Basically the question is, how do I enable permissions on dataset/NFS share in the way docker will work. I thought everyone@ should do the trick.
I also guess I'm missing something stupid.
TIA
On Alpine side:
)TRUENAS_IP:/mnt/myvolume /mnt/myvolume nfs4 rw,hard,intr,rsize=8192,wsize=8192,timeo=14 0 0
TIA
