SOLVED Configuring Dataset and NFS permissions for virtualized docker
mihies
Hi guys,
I'm running alpine as virtual machine and within it the docker. I'd like to use mounted ZFS datasets for docker volumes.
On TrueNAS (Cobia) side:
I have a local group docker_share consisting with root and my username members.
I'd create a dataset, set its ACL Mode to SMB/NFS4, set owner user to root and group to docker_share, set NFS4 permissions to user@, group@ and everyone@ to Full Control.
Then I'd enable NFS share for said dataset.
On Alpine side:
I'd mount NFS share from above (fstab:
TRUENAS_IP:/mnt/myvolume /mnt/myvolume nfs4 rw,hard,intr,rsize=8192,wsize=8192,timeo=14 0 0
It almost works except when I start a docker container using this volume it gets "Permission denied" here and there.
Basically the question is, how do I enable permissions on dataset/NFS share in the way docker will work. I thought everyone@ should do the trick.
I also guess I'm missing something stupid.
TIA
anodos
Sambassador
Hi guys,
On Alpine side:
TIA
What operations are being rejected?
mihies
Here is an example of tt-rss whining when it is created from scratch:
app-1 | adduser: /var/www/html: Operation not permitted
app-1 | cp: can't create '/var/www/html/index.php': Permission denied
docker mount is like
- /mnt/tt-rss/app:/var/www/html
and ls -la /mnt/tt-rss yields
drwxr-xr-x 2 1100 66533 2 Feb 16 15:06 app
drwxr-xr-x 2 dockrema nogroup 2 Feb 16 15:06 config.d
drwx------ 19 170 nogroup 25 Feb 16 15:07 data
If I use a local volume, everything is fine.
Sidenote: I'm using container isolation with user namespaces as described in https://wiki.alpinelinux.org/wiki/Docker
When I restart the container, then postgres yields errors as well, such as
find: /var/lib/postgresql/data: Permission denied
where volume is mounted as
- /mnt/tt-rss/data:/var/lib/postgresql/data
and has been populated during creation.
Does this clear anything?
mihies
I guess the container namespace isolation is at play here. Turning it off does the trick and everything works as expected.
