Chris Tobey
- Feb 11, 2014
Hi Everyone,
I have a new SuperStorage Server 6048R-E1CR24N from SuperMicro (https://www.supermicro.com/products/system/4U/6048/SSG-6048R-E1CR24N.cfm) that I would like to use a new FreeNAS build and would like some input as to the optimal configuration I can make, as well as any hardware I might want to reconsider.
So here is the parts breakdown:
Chassis: SuperMicro 6048R-E1CR24N
Motherboard: SuperMicro x10DRi-T4+
CPU: 2 x Intel E5-2620v3 (6 core/12 thread @ 2.4GHz per)
RAM: 12 x SuperMicro DR416L-SL01-ER21 (Samsung, 16GB DDR4 2133 ECC Registered)
HBA: SuperMicro AOC-S3108L-H8IR-O-P (LSI MegaRAID 8-port SAS 12Gb/s)
HDDs: 12 x Seagate ST4000NM0023 (4TB SAS 6Gb/s)
SSDs: 2 x Samsung 840 Pro 128GB
Network: ChelsIO T420-LL-CR (2 x SFP+ for 10G Fibre)
UPS: APC SMT3000RMT2U
So when I went to set this up I ran into my first problem, being that the SuperMicro HBA was a MegaRAID card with the "SAS-MFI BIOS". I scrapped that and ordered an LSI SAS 9300-8i (with the 3008 chip) which I believe should give me direct drive access.
The server will be used primarily for NFS exports with one SFP+ connected with 10G fibre to my main switch as the only network connection.
So my questions are:
1. Are there any problems with this proposed setup?
2. What do I need to do to flash / configure the LSI SAS 9300-8i?
3. What is the best configuration of the 12 HDDs and 2 SSDs? (2 x 6 RAIDZ-2 + Mirrored ZIL?)
4. Does anyone know which driver option to use for the APC SMT3000RMT2U (upgraded to latest firmware)
Thanks everyone!
Thanks everyone!
