Configurable alerts for when zpool
Rickinfl
Ok. I have 2 - 4 TB drives striped for my camera's. I have 16 camera's recording to them. I need to Stop the warnings on JUST that pool. I could care less about those drives so please don't tell me to expand my pool, add more drives. Etc.... If they blow up... oh well I could care less. I just want the warnings to STOP. Last time I just reformatted all 16 partitions and started over now they filled up again. The camera's will Automatically overwrite the partitions, but to shut those freaking warnings up I had to format.
We need someway to stop or adjust (If adjust then about 10 warnings before you proceed to disable lol) Or say silence them for X amount of days, BUT ONLY FOR THAT POOL. I want my main pool to warn me if there is a problem.
Rickinfl
The Capacity for the volume NVR is currently at 80% while the recommended value is below 80%
garm
Suspected that, you really don’t want to pass 90% as ZFS will go into emergency mode to try and save the pool. To give a comfy margin to the 90% limit and also preserve performance you should really not pass 80%.
You can solve the alert issue by nesting your 16 datasets in a parent dataset and set a quota for that dataset and all its children to 79%
