Completely f**ked up my qBittorrent
theaoneone
Newbie
I accidentally upgraded my qBittorrent to the new version and now the WebGUI doesn't work completely.
Things I have tried.
Removing the /.config/qBittorrent/qbittorrent.conf file
Editing the config file, and a lot of other things.
putting in a new config file from a new install
Any idea of how to migrate this qBittorrent data to another jail?
Only the WebGui doesn't work and the client itself still works.
Where does it save the data files so I can migrate it?
There are literally 2k+ torrents.
Jailer
Not strong, but bad
Jailer
Not strong, but bad
Have you tried restarting the service?
winnielinnie
Member
The webGUI just refuse to connect. Simply don't work.
What message does your web browser give you when you try to connect to the qBittorrent web GUI?
Which data files do you mean? The actual files downloaded from torrents?
How did you update, via the Plugin menu or the Jail menu? Do you have a snapshot of the jail from an earlier version you can revert to?
