Jakenaked
- Aug 23, 2014
TL;DR version: I accidentally CHMOD 777 my entire qBittorrent jail, now the webGUI won't come up.
So, in my efforts to fix an issue I was having with my freeNAS file server / download box I seem to have broken my qBittorrent and Sickbeard jail. For the purpose of this post I am really only concerned with the qBittorrent jail, I can worry about Sickbeard another day.
The problem started when I was trying to fix an issue I was having with my download folders. I had my jails kind of threeway sharing a central download folder where Sickbeard would scrape TV info and sort the file. Sickbeard was having trouble showing / processing files I had downloaded with qBittorrent. After a little messing around it seemed the permissions for the downloaded files was the problem. So I decided (foolishly) to chmod 777 the files. Being pretty new to Nix I did something really stupid and cd'd to my download folder and then "CHMOD -r 777 /" I think for some reason I was thinking the / would just hit the files in that folder. Yeah. Derp.
I didn't notice any issue at all at first, but then a couple of weeks after we had a huge thunderstorm here that knocked the power out. My UPS kicked in and the system appears to have shut down normally (The email notification worked correctly and said the system was going down.) I got back home, turned the system back on and didn't think anything of it. I didn't notice anything was wrong for 2-3 when I went to log into my qBittorrent webGUI. It was at that point I realized I wasn't able to login to my qBittorrent or Sickbeard webGUIs. The jail itself is set up to auto-connect to a VPN service. I don't think that is causing an issue since I can see the tunnel being created in the freeNAS log. I could disable it to check, but being a BSD newbie just getting the thing working was kind of a pain.
I suppose nuking the jails and setting everything back up wouldn't be too hard but I'd like to avoid it if possible. Does loading a backup config have any effect on the contents of the jails or is it just the freeNAS settings basically noting that the jails exist?
Any help would be greatly appreciated. I posted a bunch of output for the commands I could think of below. If there is a specific output you want to see just let me know and I will try to get it posted ASAP. I didn't post a ton of hardware info since I think this is mostly a config issue rather than a hardware one, but if it is important please let me know and I will post that info also.
System log after a start / stop of qBittorrent jail:
qBittorrent shell outputs:
From my qBittorrent jail I am able to ping freeNAS's IP and freeNAS's default gateway (192.168.1.1). I can even ping (but not SSH into) the qBittorrent jail from my Windows machine on the same network.
Lastly, my sickbeard webGUI doesn't work either, I can see an error message in the freeNAS log whenever I start the jail:
Thanks again! :D
Oct 21 05:46:14 freenas notifier: Performing sanity check on nginx configuration: Oct 21 05:46:14 freenas notifier: nginx: the configuration file /usr/local/etc/nginx/nginx.conf syntax is ok Oct 21 05:46:14 freenas notifier: nginx: configuration file /usr/local/etc/nginx/nginx.conf test is successful Oct 21 05:46:14 freenas kernel: epair0a: Ethernet address: 02:ba:91:00:0a:0a Oct 21 05:46:14 freenas kernel: epair0b: Ethernet address: 02:ba:91:00:0b:0b Oct 21 05:46:14 freenas kernel: epair0a: link state changed to UP Oct 21 05:46:14 freenas kernel: epair0b: link state changed to UP Oct 21 05:46:14 freenas kernel: epair0a: promiscuous mode enabled Oct 21 05:46:14 freenas kernel: ng_ether_ifnet_arrival_event: can't re-name node epair0b Oct 21 05:46:19 freenas kernel: tun0: link state changed to UP Oct 21 05:48:20 freenas kernel: epair0a: link state changed to DOWN Oct 21 05:48:20 freenas kernel: epair0b: link state changed to DOWN Oct 21 05:48:20 freenas kernel: tun0: link state changed to DOWN Oct 21 05:48:24 freenas kernel: ifa_del_loopback_route: deletion failed Oct 21 05:48:24 freenas kernel: Freed UMA keg (udp_inpcb) was not empty (20 items). Lost 2 pages of memory. Oct 21 05:48:24 freenas kernel: Freed UMA keg (udpcb) was not empty (336 items). Lost 2 pages of memory. Oct 21 05:48:24 freenas kernel: Freed UMA keg (tcp_inpcb) was not empty (10 items). Lost 1 pages of memory. Oct 21 05:48:24 freenas kernel: Freed UMA keg (tcpcb) was not empty (4 items). Lost 1 pages of memory. Oct 21 05:48:24 freenas kernel: hhook_vnet_uninit: hhook_head type=1, id=1 cleanup required Oct 21 05:48:24 freenas kernel: hhook_vnet_uninit: hhook_head type=1, id=0 cleanup required
root@qBittorrent:/ # dmesg ifa_del_loopback_route: deletion failed Freed UMA keg (udp_inpcb) was not empty (20 items). Lost 2 pages of memory. Freed UMA keg (udpcb) was not empty (336 items). Lost 2 pages of memory. Freed UMA keg (tcp_inpcb) was not empty (20 items). Lost 2 pages of memory. Freed UMA keg (tcpcb) was not empty (12 items). Lost 3 pages of memory. Freed UMA keg (ripcb) was not empty (20 items). Lost 2 pages of memory. hhook_vnet_uninit: hhook_head type=1, id=1 cleanup required hhook_vnet_uninit: hhook_head type=1, id=0 cleanup required
root@qBittorrent:/ # ifconfig
options=600003<RXCSUM,TXCSUM,RXCSUM_IPV6,TXCSUM_IPV6>
inet6 ::1 prefixlen 128
inet6 fe80::1%lo0 prefixlen 64 scopeid 0x1
epair0b: flags=8843<UP,BROADCAST,RUNNING,SIMPLEX,MULTICAST> metric 0 mtu 1500
options=8<VLAN_MTU>
ether 02:66:bc:00:0c:0b
inet 192.168.1.248 netmask 0xffffff00 broadcast 192.168.1.255
status: active
tun0: flags=8051<UP,POINTOPOINT,RUNNING,MULTICAST> metric 0 mtu 1500
options=80000<LINKSTATE>
inet 10.8.0.198 --> 10.8.0.197 netmask 0xffffffff
nd6 options=1<PERFORMNUD>
Opened by PID 90772
root@qBittorrent:/ # Code:
root@qBittorrent:/ # netstat -r Routing tables Internet: Destination Gateway Flags Refs Use Netif Expire 0.0.0.0/1 10.8.0.197 UGS 0 11 tun0 => default 192.168.1.1 UGS 0 39 epair0 10.8.0.1/32 10.8.0.197 UGS 0 0 tun0 10.8.0.197 link#3 UH 0 0 tun0 10.8.0.198 link#3 UHS 0 0 lo0 localhost link#1 UH 0 0 lo0 128.0.0.0/1 10.8.0.197 UGS 0 0 tun0 192.99.7.206/32 192.168.1.1 UGS 0 57 epair0 192.168.1.0 link#2 U 0 15 epair0 qBittorrent link#2 UHS 0 0 lo0 Internet6: (Not used) root@qBittorrent:/ #
Oct 21 05:51:55 freenas manage.py: [freeadmin.navtree:526] Couldn't retrieve http://192.168.1.254/plugins/sickbeard/2/_s/treemenu: HTTP Error 502: Bad Gateway
Thanks again! :D
