You should try to find one compatible with NUT. http://networkupstools.org/stable-hcl.html
I've had good luck with the APC Smart UPS 1500 (can't remember the exact model number). I also have configured it with an Eaton 5P 1500R. I think the Cyberpower CP685AVR is also a fairly commonly used one.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
