Hello all,
I've built up a new FreeNAS box from an ASRock Rack C3758D4I-4L board. This board has quite a few onboard SATA ports.
The drive firmware is the latest per Seagate.
I've moved the drives a few times while troubleshooting, so the devices won't line up between 'camcontrol' and the messages thrown when FreeNAS is timing out.
- Motherboard ASRock C3758D4i-4L
- CPU: Intel Atom C3758
- RAM: 2x 32 GB
- Hard drives: 2x Seagate Ironwolf 110 SSDs, 1.92T each
- Hard disk controllers: Onboard first (causing troubles), then LSI-9211 (works)
- Network cards: 4x onboard Marvell, appearing as Intel
- Power supply is a PC Power & Cooling 500W (overkill, but taken from another box).
freenas# camcontrol devlist <ATA ZA1920NM10001 011J> at scbus0 target 25 lun 0 (pass0,da0) <ATA ZA1920NM10001 011J> at scbus0 target 26 lun 0 (pass1,da1) <ADATA ISMS331-016GMV P0831A> at scbus1 target 0 lun 0 (ada0,pass2) <AHCI SGPIO Enclosure 2.00 0001> at scbus5 target 0 lun 0 (ses0,pass3) <Samsung SSD 840 EVO 250GB EXT0DB6Q> at scbus6 target 0 lun 0 (pass5,ada1) <Samsung SSD 840 EVO 250GB EXT0BB6Q> at scbus7 target 0 lun 0 (pass6,ada2) <AHCI SGPIO Enclosure 2.00 0001> at scbus11 target 0 lun 0 (ses1,pass4)
freenas# smartctl -x /dev/da0
smartctl 7.0 2018-12-30 r4883 [FreeBSD 12.1-STABLE amd64] (local build)
Copyright (C) 2002-18, Bruce Allen, Christian Franke, www.smartmontools.org
Model Family: Seagate IronWolf 110 SATA SSD
Device Model: ZA1920NM10001
Serial Number: HKS01KQ0
LU WWN Device Id: 5 000c50 03ea14015
Firmware Version: SF44011J
User Capacity: 1,920,383,410,176 bytes [1.92 TB]
Rotation Rate: Solid State Device
ATA Version is: ACS-4, ACS-2 T13/2015-D revision 3
SATA Version is: SATA 3.3, 6.0 Gb/s (current: 6.0 Gb/s)
Local Time is: Sun Mar 22 22:26:11 2020 EDT
SMART support is: Enabled
AAM feature is: Unavailable
APM level is: 1 (minimum power consumption with standby)
Rd look-ahead is: Enabled
Write cache is: Enabled
DSN feature is: Disabled
ATA Security is: Disabled, NOT FROZEN [SEC1]
Wt Cache Reorder: Enabled
General SMART Values:
was never started.
been run.
data collection: ( 0) seconds.
capabilities: (0x59) SMART execute Offline immediate.
No Auto Offline data collection support.
command.
Self-test supported.
SMART capabilities: (0x0002) Does not save SMART data before
entering power-saving mode.
Short self-test routine
Extended self-test routine
recommended polling time: ( 30) minutes.
SCT capabilities: (0x103d) SCT Status supported.
SCT Data Table supported.
SMART Attributes Data Structure revision number: 11
ID# ATTRIBUTE_NAME FLAGS VALUE WORST THRESH FAIL RAW_VALUE
1 Raw_Read_Error_Rate POSR-K 100 100 090 - 0
5 Reallocated_Sector_Ct -O--CK 100 100 000 - 0
9 Power_On_Hours -O--CK 100 100 000 - 88
12 Power_Cycle_Count -O--CK 100 100 000 - 23
100 Flash_GB_Erased -O--CK 100 100 000 - 11
102 Lifetime_PS4_Entry_Ct -O--CK 100 100 000 - 13
103 Lifetime_PS3_Exit_Ct -O--CK 100 100 000 - 9
170 Grown_Bad_Block_Ct -O--CK 100 100 000 - 0
171 Program_Fail_Count -O--CK 100 100 000 - 0
172 Erase_Fail_Count -O--CK 100 100 000 - 0
173 Avg_Program/Erase_Ct -O--CK 100 100 000 - 1
174 Unexpected_Pwr_Loss_Ct -O--CK 100 100 000 - 19
177 Wear_Range_Delta PO---K 100 100 089 - 0 0 0
183 SATA_Downshift_Count -O--CK 100 100 000 - 0x00000000000000
187 Uncorrectable_ECC_Ct -O--CK 100 100 000 - 0
194 Temperature_Celsius -O---K 030 049 000 - 30 (Min/Max 23/49)
195 RAISE_ECC_Cor_Ct -O--CK 100 100 000 - 0
198 Uncor_Read_Error_Ct -O--CK 100 100 000 - 0
199 UDMA_CRC_Error_Count -O--CK 100 100 000 - 0
230 Drv_Life_Protect_Status PO---K 100 100 091 - 100
231 SSD_Life_Left PO--CK 100 100 010 - 0x00000000646400
232 Available_Reservd_Space POS--K 100 100 003 - 0
233 Lifetime_Wts_To_Flsh_GB -O--CK 100 100 000 - 14
241 Lifetime_Wts_Frm_Hst_GB -O--CK 100 100 000 - 39
242 Lifetime_Rds_Frm_Hst_GB -O--CK 100 100 000 - 0
243 Free_Space -OS--K 100 100 003 - 0x07270200218b89
||||||_ K auto-keep
|||||__ C event count
||||___ R error rate
|||____ S speed/performance
||_____ O updated online
|______ P prefailure warning
General Purpose Log Directory Version 1
SMART Log Directory Version 1 [multi-sector log support]
Address Access R/W Size Description
0x00 GPL,SL R/O 1 Log Directory
0x02 SL R/O 16 Comprehensive SMART error log
0x03 GPL R/O 20 Ext. Comprehensive SMART error log
0x04 GPL,SL R/O 8 Device Statistics log
0x06 SL R/O 1 SMART self-test log
0x07 GPL R/O 1 Extended self-test log
0x09 SL R/W 1 Selective self-test log
0x0a GPL R/W 16 Device Statistics Notification
0x0c GPL R/O 1 Pending Defects log
0x10 GPL R/O 1 NCQ Command Error log
0x11 GPL R/O 1 SATA Phy Event Counters log
0x12 GPL R/O 1 SATA NCQ Non-Data log
0x13 GPL R/O 1 SATA NCQ Send and Receive log
0x24 GPL R/O 65535 Current Device Internal Status Data log
0x25 GPL R/O 65535 Saved Device Internal Status Data log
0x30 GPL,SL R/O 9 IDENTIFY DEVICE data log
0x80-0x9f GPL,SL R/W 16 Host vendor specific log
0xa8 SL VS 255 Device vendor specific log
0xb7 GPL VS 1024 Device vendor specific log
0xd4 GPL,SL VS 6 Device vendor specific log
0xe0 GPL,SL R/W 1 SCT Command/Status
0xe1 GPL,SL R/W 1 SCT Data Transfer
0xf7 SL - 2 Reserved
0xf8 SL - 1 Reserved
0xf9 SL - 4 Reserved
0xfa SL - 7 Reserved
0xfb GPL - 65535 Reserved
SMART Extended Comprehensive Error Log Version: 1 (20 sectors)
No Errors Logged
SMART Extended Self-test Log Version: 1 (1 sectors)
No self-tests have been logged. [To run self-tests, use: smartctl -t]
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
SCT Status Version: 3
SCT Version (vendor specific): 0 (0x0000)
Device State: Active (0)
Current Temperature: 33 Celsius
Power Cycle Min/Max Temperature: 29/35 Celsius
Lifetime Min/Max Temperature: 23/49 Celsius
Specified Max Operating Temperature: 116 Celsius
Under/Over Temperature Limit Count: 0/0
SMART Status: 0xc24f (PASSED)
SCT Temperature History Version: 2
Temperature Sampling Period: 1 minute
Temperature Logging Interval: 1 minute
Min/Max recommended Temperature: -10/116 Celsius
Min/Max Temperature Limit: -10/120 Celsius
Temperature History Size (Index): 478 (67)
Index Estimated Time Temperature Celsius
68 2020-03-22 14:29 28 *********
... ..(387 skipped). .. *********
456 2020-03-22 20:57 28 *********
457 2020-03-22 20:58 29 **********
... ..( 10 skipped). .. **********
468 2020-03-22 21:09 29 **********
469 2020-03-22 21:10 30 ***********
... ..( 7 skipped). .. ***********
477 2020-03-22 21:18 30 ***********
0 2020-03-22 21:19 ? -
1 2020-03-22 21:20 30 ***********
... ..( 65 skipped). .. ***********
67 2020-03-22 22:26 30 ***********
SCT Error Recovery Control:
Read: Disabled
Write: Disabled
Device Statistics (GP Log 0x04)
Page Offset Size Value Flags Description
0x01 ===== = = === == General Statistics (rev 1) ==
0x01 0x008 4 23 --- Lifetime Power-On Resets
0x01 0x010 4 88 --- Power-on Hours
0x01 0x018 6 82842176 --- Logical Sectors Written
0x01 0x020 6 3160294 --- Number of Write Commands
0x01 0x028 6 103285 --- Logical Sectors Read
0x01 0x030 6 4516 --- Number of Read Commands
0x01 0x038 6 317265966 --- Date and Time TimeStamp
0x01 0x058 2 65447 --- Resource Availability
0x04 ===== = = === == General Errors Statistics (rev 1) ==
0x04 0x008 4 0 --- Number of Reported Uncorrectable Errors
0x04 0x010 4 0 --- Resets Between Cmd Acceptance and Completion
0x05 ===== = = === == Temperature Statistics (rev 1) ==
0x05 0x008 1 30 --- Current Temperature
0x05 0x010 1 28 --- Average Short Term Temperature
0x05 0x018 1 - --- Average Long Term Temperature
0x05 0x020 1 49 --- Highest Temperature
0x05 0x028 1 23 --- Lowest Temperature
0x05 0x030 1 32 --- Highest Average Short Term Temperature
0x05 0x038 1 26 --- Lowest Average Short Term Temperature
0x05 0x040 1 - --- Highest Average Long Term Temperature
0x05 0x048 1 - --- Lowest Average Long Term Temperature
0x05 0x050 4 0 --- Time in Over-Temperature
0x05 0x058 1 116 --- Specified Maximum Operating Temperature
0x05 0x060 4 0 --- Time in Under-Temperature
0x05 0x068 1 -10 --- Specified Minimum Operating Temperature
0x06 ===== = = === == Transport Statistics (rev 1) ==
0x06 0x008 4 106 --- Number of Hardware Resets
0x06 0x010 4 97 --- Number of ASR Events
0x06 0x018 4 0 --- Number of Interface CRC Errors
0x07 ===== = = === == Solid State Device Statistics (rev 1) ==
0x07 0x008 1 0 --- Percentage Used Endurance Indicator
|||_ C monitored condition met
||__ D supports DSN
|___ N normalized value
Pending Defects log (GP Log 0x0c)
No Defects Logged
SATA Phy Event Counters (GP Log 0x11)
ID Size Value Description
0x0001 2 0 Command failed due to ICRC error
0x0003 2 0 R_ERR response for device-to-host data FIS
0x0004 2 0 R_ERR response for host-to-device data FIS
0x0006 2 0 R_ERR response for device-to-host non-data FIS
0x0007 2 0 R_ERR response for host-to-device non-data FIS
0x0008 2 0 Device-to-host non-data FIS retries
0x0009 2 2 Transition from drive PhyRdy to drive PhyNRdy
0x000a 2 3 Device-to-host register FISes sent due to a COMRESET
0x000f 2 0 R_ERR response for host-to-device data FIS, CRC
0x0010 2 0 R_ERR response for host-to-device data FIS, non-CRC
0x0012 2 0 R_ERR response for host-to-device non-data FIS, CRC
0x0013 2 0 R_ERR response for host-to-device non-data FIS, non-CRC
0x0002 2 0 R_ERR response for data FIS
0x0005 2 0 R_ERR response for non-data FIS
0x000b 2 0 CRC errors within host-to-device FIS
0x000d 2 0 Non-CRC errors within host-to-device FISCode:
Mar 18 20:07:16 freenas ZFS: vdev state changed, pool_guid=2550807933382894929 vdev_guid=14584055837392843541
Mar 18 20:07:16 freenas ZFS: vdev state changed, pool_guid=2550807933382894929 vdev_guid=348865377422514070
Mar 18 20:07:46 freenas ahcich12: Timeout on slot 8 port 0
Mar 18 20:07:46 freenas ahcich12: is 00000000 cs 00000100 ss 00000100 rs 00000100 tfd 441 serr 00000000 cmd 00044717
Mar 18 20:07:46 freenas (ada4:ahcich12:0:0:0): SEND_FPDMA_QUEUED DATA SET MANAGEMENT. ACB: 64 08 00 00 00 40 00 00 00 00 00 00
Mar 18 20:07:46 freenas (ada4:ahcich12:0:0:0): CAM status: Command timeout
Mar 18 20:07:46 freenas (ada4:ahcich12:0:0:0): Retrying command
Mar 18 20:08:16 freenas ahcich12: Timeout on slot 18 port 0
Mar 18 20:08:16 freenas ahcich12: is 00000000 cs 00040000 ss 00040000 rs 00040000 tfd 441 serr 00000000 cmd 00045117
Mar 18 20:08:16 freenas (ada4:ahcich12:0:0:0): SEND_FPDMA_QUEUED DATA SET MANAGEMENT. ACB: 64 08 00 00 00 40 00 00 00 00 00 00
Mar 18 20:08:16 freenas (ada4:ahcich12:0:0:0): CAM status: Command timeout
Mar 18 20:08:16 freenas (ada4:ahcich12:0:0:0): Retrying command
Mar 18 20:08:46 freenas collectd[1666]: Traceback (most recent call last):
File "/usr/local/lib/collectd_pyplugins/disktemp.py", line 66, in read
temperatures = c.call('disk.temperatures', self.disks, self.powermode, self.smartctl_args)
File "/usr/local/lib/python3.7/site-packages/middlewared/client/client.py", line 500, in call
raise CallTimeout("Call timeout")
middlewared.client.client.CallTimeout: Call timeout
Mar 18 20:09:17 freenas ahcich12: Timeout on slot 29 port 0
Mar 18 20:09:17 freenas ahcich12: is 00000000 cs 20000000 ss 00000000 rs 20000000 tfd 441 serr 00000000 cmd 00045c17
Mar 18 20:09:47 freenas ahcich12: Timeout on slot 8 port 0
Mar 18 20:09:47 freenas ahcich12: is 00000000 cs 00000100 ss 00000100 rs 00000100 tfd 441 serr 00000000 cmd 00044717
Mar 18 20:09:47 freenas (ada4:ahcich12:0:0:0): SEND_FPDMA_QUEUED DATA SET MANAGEMENT. ACB: 64 08 00 00 00 40 00 00 00 00 00 00
Mar 18 20:09:47 freenas (ada4:ahcich12:0:0:0): CAM status: Command timeout
Mar 18 20:09:47 freenas (ada4:ahcich12:0:0:0): Retrying command
Mar 18 20:10:17 freenas ahcich12: Timeout on slot 16 port 0
Mar 18 20:10:17 freenas ahcich12: is 00000000 cs 00010000 ss 00010000 rs 00010000 tfd 441 serr 00000000 cmd 00044f17
Mar 18 20:10:17 freenas (ada4:ahcich12:0:0:0): SEND_FPDMA_QUEUED DATA SET MANAGEMENT. ACB: 64 08 00 00 00 40 00 00 00 00 00 00
Mar 18 20:10:17 freenas (ada4:ahcich12:0:0:0): CAM status: Command timeout
Mar 18 20:10:17 freenas (ada4:ahcich12:0:0:0): Retrying command
Mar 18 20:10:47 freenas ahcich12: Timeout on slot 24 port 0
Mar 18 20:10:47 freenas ahcich12: is 00000000 cs 01000000 ss 01000000 rs 01000000 tfd 441 serr 00000000 cmd 00045717
Mar 18 20:10:47 freenas (ada4:ahcich12:0:0:0): SEND_FPDMA_QUEUED DATA SET MANAGEMENT. ACB: 64 08 00 00 00 40 00 00 00 00 00 00
Mar 18 20:10:47 freenas (ada4:ahcich12:0:0:0): CAM status: Command timeout
Mar 18 20:10:47 freenas (ada4:ahcich12:0:0:0): Retrying command
Mar 18 20:11:18 freenas ahcich12: Timeout on slot 0 port 0
Mar 18 20:11:18 freenas ahcich12: is 00000000 cs 00000001 ss 00000001 rs 00000001 tfd 441 serr 00000000 cmd 00045f17
Mar 18 20:11:18 freenas (ada4:ahcich12:0:0:0): SEND_FPDMA_QUEUED DATA SET MANAGEMENT. ACB: 64 08 00 00 00 40 00 00 00 00 00 00
Mar 18 20:11:18 freenas (ada4:ahcich12:0:0:0): CAM status: Command timeout
