I just installed a backup machine with Cobia and would like to replicate the disc layout with a fusion pool of the main machine with:
- 8-wide HDD in zRAID-2
- mirrored NVMe as special vdev for metadata
In the process of creating the pool in the GUI, I cannot complete the setup and get notice that the second (special) vdev should also be zRAID-2.
In bluefin, I could obtain this config via GUI (possibly by applying a 'force' setting).
Is this different behavior really intentional? Instead of reverting to the command line to add the special vdev, I would rather set this up in a controlled way in the GUI. Via command line one has to take care to use the proper gptid instead of simple device names (this could easily go wrong and cause trouble down the road).
I think, this setup is quite reasonable from a risk / performance perspective, so why should it be so heavily discouraged?
