rlpowell submitted a new resource:
Cloud Sync monitoring script - Cloud Sync monitoring script
Read more about this resource...
Here's a small shell script that runs on one of my other hosts to monitor that my one cloudsync job works.
To use it, you'll need to change the `storage.realm` URL to something that can reach your NAS, and you'll need to change the thing after "Bearer" to your API token.
This script definitely assumes you have single cloudsync job, and will likely give false successes if you have more than one and one is failing.
Feel free to bug me if you need it tweaked; robinleepowell [at] gmail...
