<div class="bbWrapper">I have about 4TB of data to sync from FreeNAS to my Google Drive. I've previously backed up all this data with a Windows-based program called SyncBack. Works okay, but I'd rather offload that duty to my FreeNAS server. The initial upload with SyncBack took a LONG time. and even now the check of the remote data takes a very long time to scan for changes.<br />
<br />
Questions:<br />
Can I do the initial upload from FreeNAS in stages? Say, a few folders at a time instead of giving it all 4TB at once?<br />
If I do that, when I finally get it all uploaded, how does CloudSync compare the local files to the remote ones? Will it see the data uploaded in chunks as one group to be compared to the local files?<br />
After all data is in both places, how does CloudSync determine what do upload to/delete from the remote server? Does it have to scan everything on the remote server with every backup cycle?<br />
<br />
Thanks!<br />
Matt</div>
<div class="bbWrapper">I gave up on it. The Google Drive security token keeps timing out (separate issue). Until FreeNAS updates how this works, I'm not wasting more of my time on it. They may have updated it by now, but the last release notes I looked at didn't mention it and I saw no difference in the interface.</div>
<div class="bbWrapper"><blockquote data-attributes="member: 64422" data-quote="Matt Tyree" data-source="post: 527355"
class="bbCodeBlock bbCodeBlock--expandable bbCodeBlock--quote js-expandWatch">
<div class="bbCodeBlock-title">
<a href="/community/goto/post?id=527355"
class="bbCodeBlock-sourceJump"
rel="nofollow"
data-xf-click="attribution"
data-content-selector="#post-527355">Matt Tyree said:</a>
</div>
<div class="bbCodeBlock-content">
<div class="bbCodeBlock-expandContent js-expandContent ">
</div>
<div class="bbCodeBlock-expandLink js-expandLink"><a role="button" tabindex="0">Click to expand...</a></div>
</div>
</blockquote>Do you happen to know if there is a jira bug ticket for this?<br />
<br />
Sent from my phone</div>
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
