CLI Replication and specify port
Sir.Robin
I'm trying to find out why my replication fails and so i'm trying the "zfs send" command. With default ports 22 it works, but i wan't to specify a different port.
How?
Also, only one of my two NAS reports when a replication fails. Never the other. Even though it does fail from that one (at least no snapshots appear on the other side) and i do get the security logs from it wich means email is configured correct.
paleoN
Pipes are your friend.
Sir.Robin
Right... but how? :) And thanx for the last time paleoN!
Example:
zfs send repl01/Lagring@auto-20121129.0100-1w | ssh -i /data/ssh/replication mydnsname.com zfs receive vol01/Lagring@auto-20121129.0100-1w
How do i set port? I tried "mydnsname.com:portnumber" and "mydnsname.com portnumber"
but no luck. It goes for the default 22.
paleoN
OK, you know to use pipes, but you aren't understanding what they do? Your problem is an SSH problem and has nothing to do with zfs send. The zfs send command sends to standard output, the pipe redirects that to SSH and SSH does what you tell it. See the SSH man pages.
Sir.Robin
Well... i'm sort of new to it... snagged that command from some example :)
Anyway i got it working. Had to delete all snapshots and the dataset on PULL. Then auto replication functioned :)
Thanx for the link! I now also manage to manually replicate through alternative port! :cool:
