clarkson and plugin request (Truenas scale )
oldman66
Hi folks
Is it possible to add in plugin description the default user/password?
I have a small test install on my proxmox of scale and I try different apps, like Clarkson.
(record of my fuel fill ups) and tried to log in the web gui with the default admin, adminadmin.
Tried to make a new user but the app do not want that
So what is the default? Where can I fint out what that is?
web search for clarkson only list jeremy clarkson and that is the wrong clarkson
thanks
oldman66
Hi all
Tried a new app in Scal and the default login does not work in this app either.
I delete all apps that does not work and the list is getting longer.
IS there any apps that will work in scale at all?
