Hello @ all,
I just installed syncthing plugin 1.0. After installation I get following error in the web GUI:
It's not possible to set any settings at installation process except IP. So I would say it should work out of the box as it is a plugin. However I can't find any documentation on that plugin, too.
Is this failure "normal", so you have to fix it after installation? Do you know what and how to fix it? Would be great if there were some small docs about each plugin...
2019-01-29 12:37:08: Failed to create folder root directory mkdir /Sync: permission denied 2019-01-29 12:37:08: Error on folder "Default Folder" (default): folder path missing
