CIFS shares are slow on HP Microserver
Milhouse
now working with the same desktop and doing up and downloads on these systems with a 4gig image file (same file all the case) results:
upload
- freenas : 20-25000kbytes/sec
- win : 90-110kbytes/sec
download
- freenas : 40-55000kbytes/sec
- win : 70-95kbytes/sec
I'd chip in, but your figures don't make sense... you say that FreeNAS is slower? Have you got your kbytes and mbytes mixed up? If you posted figures I could understand or recognise it might help.
I get 55-60Mbytes upload from Win7 to a N36L with FreeNAS 8.3.0-RELEASE (test system), Intel NIC, readahead force enabled, 4GB RAM, 4TB RAIDZ1 (4x1TB). I would expect RAIDZ2 to be slower than this due to the additional overhead.
hi, all thoughts are appreciated.
yes freenas seems much slower. i gave in thousands of kbytes s you could say 20-25M with freenas vs 90-100 with win on up and the other nummbers are down.
since that time i have removed the raid z2 and moved on to
raidz1 - up 26-27M/sec down 50-55M/sec
zfs mirror - up 27-30M/sec down 50-55M/sec
so there is an increase but still it is the third in speed compared to the win host. :-(
made up an ufs mirror too then a zfs mirror with different disk for log then for cache.
so upload went up as max as 35M/sec. wondering whether it is due samba or driver optimization.
hey,
have made up the ftp service.
upload results a very steady 80-90M/s . with which i am ok
download results an even slower 15M/s.
so noobsauce80 my friend i do not think the device is used for something it was not meant for as it is capable to transmit
files up and down with high speed and it is what it is intended to do. So i am looking for ways of tuning regarding cifs share
plus:
as you have advised i have launched iperf as -sD on the freenas and have used iperf for win on the client machine
as following
D:\>iperf -c freenas -P 1 -i 1 -p 5001 -N -l 64K -f m -t 6000 -T 1
Client connecting to freenas, TCP port 5001
TCP window size: 0.01 MByte (default)
[188] local computer port 59836 connected with freenas port 5001
[ ID] Interval Transfer Bandwidth
[188] 0.0- 1.0 sec 112 MBytes 938 Mbits/sec
[188] 1.0- 2.0 sec 113 MBytes 950 Mbits/sec
[188] 2.0- 3.0 sec 113 MBytes 949 Mbits/sec
[188] 3.0- 4.0 sec 113 MBytes 951 Mbits/sec
[188] 4.0- 5.0 sec 113 MBytes 949 Mbits/sec
[188] 5.0- 6.0 sec 113 MBytes 949 Mbits/sec
[188] 6.0- 7.0 sec 113 MBytes 946 Mbits/sec
[188] 7.0- 8.0 sec 113 MBytes 949 Mbits/sec
[188] 8.0- 9.0 sec 113 MBytes 948 Mbits/sec
[188] 9.0-10.0 sec 113 MBytes 949 Mbits/sec
[188] 10.0-11.0 sec 113 MBytes 949 Mbits/sec
[188] 11.0-12.0 sec 114 MBytes 953 Mbits/sec
[188] 12.0-13.0 sec 113 MBytes 949 Mbits/sec
[188] 13.0-14.0 sec 113 MBytes 949 Mbits/sec
[188] 14.0-15.0 sec 113 MBytes 946 Mbits/sec
[188] 15.0-16.0 sec 111 MBytes 934 Mbits/sec
[188] 16.0-17.0 sec 113 MBytes 949 Mbits/sec
[188] 17.0-18.0 sec 113 MBytes 948 Mbits/sec
which results in the area you have said it shall with a good intel nic.
have found some of your config settings in other thread will try with that.
also i have done dd tests like this:
[root@freenas ~]# dd if=/dev/zero of=/mnt/trial/trial/ddfile bs=2048k count=50k
51200+0 records in
51200+0 records out
107374182400 bytes transferred in 857.258948 secs (125252915 bytes/sec)
[root@freenas ~]# dd if=/mnt/trial/trial/ddfile of=/dev/zero bs=2048k count=50k
51200+0 records in
51200+0 records out
107374182400 bytes transferred in 263.309119 secs (407787557 bytes/sec)
