Cifs Share Problem
vvhiteknight
Hi, I have created a volume from 5 3tb hard drives. I am also created 3 cif shares on that volume. Now when I mount all of those shares onto my macbook and add a file to one of them, it then put's the files in the other to shares as well. Basically it is treating them all as the same folder. How can I stop this?
jlpellet
I think it likely that the 3 shares point to the same mount point. If so, I'd expect any user looking at that mount point (i.e., directory) to see the same files. Seems like the easiest solution is to set up each CIFS to a separate mount point. Hope this helps.
