I have following problem with latest stable FreeNAS 9.3. There is relatively a lot of writes to system dataset. I disabled write syslog and rrd data to it and still geting around 0.5 MB writes cca every minute. So I cannot have it on storage pool because the drives will never go to sleep and it is problematic to have it on another flash drive - it is around 0.5 GB writes daily. (The reporting shows something like 1 GB writes daily.)
The iostat and zpool iostat see the I/O, but no file on /var/db/system is modified / changed and top -m io -o write does not see it.
I traced it to mounted CIFS share from Linux 3.14. The connection gets disconnected and reconnected every minute by FreeNAS (FreeNAS sends TCP F packet first), which apparently causes write to system dataset. I think the write can be related to interprocess communication between parent and child smbd process, but I am not able to confirm that with truss or ktrace.
What is exact cause of these writes to system dataset (what is saved) and is it possible to disable it? Is it possible to prevent disconnection every minute when CIFS share is mounted from Linux?
Thanks.
Thanks.
