CIFS - freenas Invalid MS-DOS function
mihai
Just a note, files copied TO the zfs share made it okay. Now I am trying to copy them BACK to Windows 7 and I get the error as in the title.
I've found similar threads posted long ago:
Here, here and here.
I've tried these sets in the [global] section for Auxuliary Parameters:
Test 1:
store dos attribute = yes
vfs objects = acl_xattr
map acl inherit = Yes
Test 2:
store dos attribute = no
map archive = no
map hidden = no
map system = no
map readonly = no
Test3:
Without any luck. Anyone have any ideas for how to fix this, or some sort of work around to get those files copied over to Windows7? I really need access to these files, as they're Quickbooks backups for accounting work I'm doing.
anodos
Sambassador
Test 1:
Test 2:
map archive = no
map hidden = no
map system = no
map readonly = no
Test3:
Are you trying to store / work off your QuickBooks file on a samba share, or are you just trying to back up to the share?
Just asking because the former won't work unless you have an enterprise license / version of QuickBooks.
You should post the following:
  • Contents of /usr/local/etc/smb4.conf
  • Entries from /var/log/samba4/log.smbd
Or even better, post a debug file ''system"->"advanced"->"save debug"
mihai
Enable SSH and root login, connect as root using SFTP.
That worked, and I was able to copy what I needed.
No, I am just using it as a backup location.
Files are attached to this post. I couldn't fit log.smbd because it was too large. I'll try on a second post.
  • debug-freenas-20160530165654.zip
  • smb4.zip
mihai
I'm trying to upload a zip file with lob.smbd which is only 3 MB, so I don't know why it's having problems. If anyone needs it let me know and I'll find another way.
anodos
Sambassador
First off, the auxiliary parameter is "store dos attributes", not "store dos attribute". Second off, turn off "hostname lookups" under 'services' -> 'CIFS'.
anodos
Sambassador
I also noticed that you're running FreeNAS on top of proxmox? There are enough people coming through the forums having problems that I wouldn't consider that a recommended configuration. If you're going to virtualize freenas, do it right. There are plenty of stickies around the forums about it.
