stefanb
- Dec 12, 2014
I had an issue with slow browsing CIFS shares.
I tried to fix it with the additional parms from cyberjock:
I took a look into the smb4.conf. There are now two entries for "ea support/store dos attributes".
First both values are set to yes, and in the second entry to no.
Will this be a problem? How can I fix it? I think the UI will recreate the smb4.conf so manually changing has no "stable" effect.
Regards
Stefan
ea support = no store dos attributes = no map archive = no map hidden = no map readonly = no map system = no veto files = /._*/.DS_Store/ delete veto files = yes hide dot files = yes
... ea support = yes store dos attributes = yes lm announce = yes time server = yes acl allow execute always = true dos filemode = yes multicast dns register = yes domain logons = no local master = yes idmap config *: backend = tdb idmap config *: range = 90000001-100000000 server role = standalone netbios name = FILER workgroup = THAVIS security = user pid directory = /var/run/samba create mask = 0660 directory mask = 0770 client ntlmv2 auth = yes dos charset = CP850 unix charset = UTF-8 log level = 1 ea support = no store dos attributes = no map archive = no map hidden = no map readonly = no map system = no veto files = /._*/.DS_Store/ delete veto files = yes hide dot files = yes
Regards
Stefan
