CIFS and smb4.conf - need somehelp
dvandoren
Ok, I'm very much a beginner with FreeNAS so I will need a bit of 'Step-by-Step' with this one. FreeNAS 9.2.1.7 was working fine for a month or so, then I lost connection on all mapped drives to the NAS. I went in to try to fix it, and thought "While im in here, I'll remove PLEX and it's jail b/c it never really worked anyhow". Well now CIFS refuse to enable. I tried many online fixes and ran into 'cannot find smb4.conf'. I am very lost, and not sure how to continue. Any advice would be appreciated!
P.S. - I was thinking about just installing a fresh FreeNAS onto the boot usb drive, but was afraid of loosing my data on the HDDs...
dvandoren
Post following information:
  • Hardware specs
  • Output of "zpool status"
  • Output of "zfs list"
  • Output of "testparm"
Hopefully I did this right. Let me know if there is anything else that can help.
System Specs
Hostnamefreenas.local
BuildFreeNAS-9.2.1.7-RELEASE-x64 (fdbe9a0)
PlatformIntel(R) Core(TM)2 Duo CPU E7400 @ 2.80GHz
Memory4064MB
System TimeMon Mar 23 08:51:27 EDT 2015
Uptime8:51AM up 1 min, 0 users
Load Average1.59, 0.76, 0.31
zpool status
pool: NasVolume
state: ONLINE
scan: scrub repaired 0 in 0h22m with 0 errors on Sun Mar 22 00:22:27 2015
NAME STATE READ WRITE CKS
UM
NasVolume ONLINE 0 0
0
raidz1-0 ONLINE 0 0
0
gptid/5870d421-3bc6-11e4-9eea-0024e8156070 ONLINE 0 0 0
gptid/590f6897-3bc6-11e4-9eea-0024e8156070 ONLINE 0 0 0
gptid/596aaa58-3bc6-11e4-9eea-0024e8156070 ONLINE 0 0 0
errors: No known data errors
zfs list
NAME USED AVAIL REFER MOUNTPOINT
NasVolume 115G 1.67T 2.05G /mnt/NasVolume
NasVolume/.system 3.94M 1.67T 234K /mnt/NasVolume/.system
NasVolume/.system/cores 1.24M 1.67T 1.24M /mnt/NasVolume/.system/cores
NasVolume/.system/rrd 192K 1.67T 192K /mnt/NasVolume/.system/rrd
NasVolume/.system/samba4 1.37M 1.67T 1.37M /mnt/NasVolume/.system/samba4
NasVolume/.system/syslog 938K 1.67T 938K /mnt/NasVolume/.system/syslog
NasVolume/Movies 2.14G 1.67T 2.14G /mnt/NasVolume/Movies
NasVolume/UserFolders 110G 1.67T 11.3M /mnt/NasVolume/UserFolders
NasVolume/UserFolders/David 11.0G 1.67T 11.0G /mnt/NasVolume/UserFolders/David
NasVolume/UserFolders/Erin 99.4G 1.67T 13.2G /mnt/NasVolume/UserFolders/Erin
NasVolume/UserFolders/Erin/Time-Machine 86.2G 1.67T 86.2G /mnt/NasVolume/UserFolders/Erin/Time-Machine
Testparm
Load smb config files from /usr/local/etc/smb4.conf
max_open_files: increasing sysctl_max (11095) to minimum Windows limit (16384)
rlimit_max: increasing rlimit_max (11095) to minimum Windows limit (16384)
params.c:OpenConfFile() - Unable to open configuration file "/usr/local/etc/smb4.conf":
No such file or directory
Error loading services.
Thanks!
anodos
Sambassador
Okay a few things to note off the bat -
1) You are not using ECC RAM. This is not recommended.
2) You are using less than the recommended amount of RAM. This is advised against.
That being said, I don't think that (1) or (2) are related to the problem you are experiencing.
  • I don't have a 9.2.x system to look at, but there is a chance that permissions on /usr/local/etc may be wrong and that your smb4.conf file cannot be written to it.
  • Post output of "ls -l /usr/local" and "ls -l /usr/local/etc"
  • Post relevant log entries from /var/log/messages and /var/log/samba4/log.smbd
There may be a problem with permissions on your .system dataset.
  • Post output of "getfacl /mnt/NasVolume/.system"
It is also possible that your FreeNAS install is corrupted. If there is no clear indication of where the problem lies from the above output, then
  • backup/download your FreeNAS config
  • get a fresh USB flash drive
  • install FreeNAS 9.2.1.x on the fresh USB flash drive
  • turn off server
  • remove current USB flash drive and replace with new one
  • boot and apply config
dvandoren
root@freenas ~]# ls -1 /usr/local
bin
etc
include
lib
libdata
libexec
modules
sbin
share
www
x86_64-portbld-freebsd9.2
root@freenas ~]# ls -1 /usr/local/etc
CORBA
X11
afp.conf
afp.conf.dist
avahi
bash_completion.d
collectd.conf
collectd.conf.sample
dbus-1
dbus-session.conf.netatalk
dconf
devd
extmap.conf
extmap.conf.dist
fonts
gconf
gnome
gnome-vfs-2.0
gnome.subr
inadyn-mt
inadyn-mt.conf
istgt
ldap.conf.dist
CORBA
X11
afp.conf
afp.conf.dist
avahi
bash_completion.d
collectd.conf
dbus-1
dconf
devd
extmap.conf
extmap.conf.dist
fonts
gconf
gnome
gnome-vfs-2.0
gnome.subr
inadyn-mt
inadyn-mt.conf
istgt
ldap.conf.dist
CORBA
X11
afp.conf
afp.conf.dist
avahi
bash_completion.d
collectd.conf
dbus-1
dconf
devd
extmap.conf
extmap.conf.dist
fonts
gconf
gnome
gnome-vfs-2.0
gnome.subr
inadyn-mt
inadyn-mt.conf
istgt
ldap.conf.dist
This folder appears to be empty. Did 'ls -a' and no files shown.
# file: /mnt/NasVolume/.system
# owner: root
# group: wheel
owner@:rwxpDdaARWcCos:fd----:allow
group@:rwxpDdaARWcCos:fd----:allow
everyone@:r-x---a-R-c---:fd----:allow
I have no problem doing a fresh install of FreeNAS. Resetting up permissions and users is no big deal (since I only have 3 users). I just dont want to lose my data on the drives. Is there a way (possibly a tutorial) to reestablish my pool(?) to the new install?
Thanks for taking your time to help me!
anodos
Sambassador
bin
etc
include
lib
libdata
libexec
modules
sbin
share
www
CORBA
X11
afp.conf
afp.conf.dist
avahi
bash_completion.d
collectd.conf
dbus-1
dconf
devd
extmap.conf
extmap.conf.dist
fonts
gconf
gnome
gnome-vfs-2.0
gnome.subr
inadyn-mt
inadyn-mt.conf
istgt
ldap.conf.dist
CORBA
X11
afp.conf
afp.conf.dist
avahi
bash_completion.d
collectd.conf
dbus-1
dconf
devd
extmap.conf
extmap.conf.dist
fonts
gconf
gnome
gnome-vfs-2.0
gnome.subr
inadyn-mt
inadyn-mt.conf
istgt
ldap.conf.dist
CORBA
X11
afp.conf
afp.conf.dist
avahi
bash_completion.d
collectd.conf
dbus-1
dconf
devd
extmap.conf
extmap.conf.dist
fonts
gconf
gnome
gnome-vfs-2.0
gnome.subr
inadyn-mt
inadyn-mt.conf
istgt
ldap.conf.dist
# owner: root
# group: wheel
  • Back up your config: System → Settings → General → Save Config
  • Swap USB sticks with new one
  • Restore your config
This procedure will not touch your data.
