chmod operation not permitted
Catsrules
Member
I have a few files that somehow the permissions got changed around locally on freenas. So the owner of the files can not longer write. -r-xrwxr-x+
I am logged in as the local root user, and I am attempting to change the files permissions.
I have run this command
chmod 776 -R Folername
however I get a return of operation not permitted for every file in the folder.
I have also tried
chmod 1776 -R Foldername
With the same result.
I can do basically everything else rm filename and chown -R root Foldername
I am sure it is something really simple I am missing but I can't figure it out.
DrKK
FreeNAS Generalissimo
Try disabling the CIFS service (or NFS or AFP, whatever you're using).
Catsrules
Member
I disabled all services, and shutdown all of the Jails (some have access to that particular folder via the storage option in the Jail tab)
But I still receive operation not permitted.
I also rebooted freenas just for good measure. But it didn't help.
anodos
Sambassador
ZFS aclmode property of your dataset is set to 'restricted'. This probably happened because you configured it to have 'Windows' permissions. Chmod tends to break nfsv4 acls hence it is disallowed.
If you absolutely must use chmod on the dataset, you can set the ZFS aclmode property to 'passthrough'. See ZFS manpage for syntax.
SweetAndLow
Sweet'NASty
You can also modify the permissions using the windows security GUI.
Catsrules
Member
Yep that was it. I disabled the windows permission then reset all permissions then turned windows permission back on. I had to reset up all permission but that wasn't to bad.
Thanks for your help
I have tried this but for some reason it did not work. And according to the windows security GUI the owner user already had full control when in fact it only had read access.
Not-very-passive-but-aggressive
How can the owner be limited to read-only? The easy fix for that is the GUI option to apply sane defaults.
ric
Member
When I tried to access owncloud in my browser, I got the following error message:
And I'm getting same type of error when using chmod. See below:
root@customplugin_1:/ # chmod 770 -R /media
chmod: -R: No such file or directory
chmod: /media: Operation not permitted
I've tried disabling in windows GUI with no success. Got the same error "user already had full control".
I followed the above instruction by disabling and resetting windows permission but same result.
Please help!
ric
Member
I cant seem to find the syntax on how to set the ZFS aclmode property to 'passthrough', Can you please help? Thanks
anodos
Sambassador
The proper way to achieve this through the GUI is to change the dataset permissions type to "UNIX" with the caveat that you shouldn't do this on samba shares (unless you have good reason to do so).
ric
Member
In addition to 'chmod: Operation not permitted' , I'm unable to change the dataset permission from GUI under Unix > other, I tried to uncheck both Read & Write and hit Change, but nothing happened.
anodos
Sambassador
In addition to 'chmod: Operation not permitted' , I also have problem changing the dataset permission from GUI, doesn't allow me to make any changes.
Please create new forum thread describing your problem in detail. Include whether you are trying to share the directory through owncloud and samba simultaneously, and how your media directory is mounted into your owncloud jail.
