There is no such file, ZFS checksums is a filesystem feature on block level. The values are stored as block metadata. If you want to manually check data integrity you need to calculate each files checksum and compare.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
