We started getting checksum errors on one of our drives about a month ago, that caused the pool to go to unhealthy, and then eventually degraded status. So, we figured we had a bad disk. We replaced it.
The problem recurred with the brand new disk. That seemed odd, so I started googling.
The consensus here is that it's often a faulty cable or bad connection. So, as part of this thread (VMware, iSCSI, dropped connections and lockups), I swapped out my drive controllers AND cables. The problem persists.
So, we thought "maybe the backplane is the cause" and we swapped the disk to a different port on a different backplane. The problem stays with the drive.
Now, normally, I would say "ok, so it's a bad drive" and replace it. But when the original drive and a BRAND NEW drive have exactly the same issue, and I've replaced all the connections, I am at a loss.
What else can I do to get to the bottom of this?
NOTE: The original drives are all HGST HUH728080AL4200 8TB disks. When we replaced the original disk, we were unable to find that model brand new -- only refurb, so we replaced it with a model that had the same base specs (performance, size, RPM, sectors [4kn]), a SEAGATE STMPSKD1CLAR8000.
I know it's not optimal to use a different drive, but since the problem is identical to the HGST, it's hard to say for certain that the mismatch is the cause. I have not had time to take the original HGST drive and do a long test on it in another machine, but I suspect that the original drive is just fine, and something else is causing these checksum errors.
I'm not sure that my other thread directly relates to this or not, but I will post a link to this one there, as well, so people have the full story of what is going on with our system.
