Razvan-Dorel CIOARGA
- Dec 22, 2014
Hi all,
After some blackouts I had at my home, my installation of FreeNAS started to give some checksum errors on the boot partion (I use latest FreeNAS 9.3 with a 16 GB usb Kingston stick).
So, I did a scrub, but the checksum error remained:
pool: freenas-boot
state: ONLINE
status: One or more devices has experienced an unrecoverable error. An
attempt was made to correct the error. Applications are unaffected.
see: http://illumos.org/msg/ZFS-8000-9P
scan: scrub repaired 0 in 0h1m with 0 errors on Sun Dec 21 02:55:09 2014
NAME STATE READ WRITE CKSUM
freenas-boot ONLINE 0 0 0
da0p2 ONLINE 0 0 1
errors: No known data errors
zpool clear removed the error. The error reappeared after another scrub, so I decided to format the stick. Formatted the usb stick, installed FreeNAS from scratch, uploaded config db, everything is working fine.
For a day!
1 hour ago I get an email from my box with the same error. Another scrub later, another clean, another scrub the error disappeared.
I have 3 x 1 TB WD RED in RaidZ1, 8 GB RAM ECC.
Should I run some memory tests, could it be the RAM (I don't think so, but ...).
Should I change the usb stick?
Thanks for your help!
pool: freenas-boot
state: ONLINE
da0p2 ONLINE 0 0 1
For a day!
