Hi, having speed issues on my pool.
I did a scrub, and still have CKSUM errors :
I did a long test on my ada3 :
I did change my sata cable en still having this CKSUM increasing.
I did run a long memtest without error
199 UDMA_CRC_Error_Count seems to be hihg, nope ?
thanks !
PS : I d'ont know if it could be related, but I can't proper restar my freenas or shutdown, freeze on :
[root@freenas] ~# zpool status -v
pool: gra1
state: ONLINE
status: One or more devices has experienced an unrecoverable error. An
attempt was made to correct the error. Applications are unaffected.
see: http://www.sun.com/msg/ZFS-8000-9P
scan: scrub repaired 248M in 10h27m with 0 errors on Tue May 14 10:18:18 2013
NAME STATE READ WRITE CKSUM
gra1 ONLINE 0 0 0
raidz1-0 ONLINE 0 0 0
gptid/f53806cb-fab1-11e1-89d0-14dae98ee84a ONLINE 0 0 0
gptid/59d2f087-5436-11e2-aa3a-14dae98ee84a ONLINE 0 0 0
gptid/19f779b3-e63a-11e0-9acd-14dae98ee84a ONLINE 0 0 0
gptid/bbc24e0e-1e2d-11e1-866b-14dae98ee84a ONLINE 0 0 75
errors: No known data errors
[root@freenas] ~# smarctl -a /dev/ada3
CORRECT>smartctl -a /dev/ada3 (y|n|e|a)? yes
smartctl 5.43 2012-06-30 r3573 [FreeBSD 8.3-RELEASE-p5 amd64] (local build)
Copyright (C) 2002-12 by Bruce Allen, http://smartmontools.sourceforge.net
Model Family: Western Digital AV-GP
Device Model: WDC WD15EVDS-63V9B1
Serial Number: WD-WMAVU3745542
LU WWN Device Id: 5 0014ee 0ad1c8197
Firmware Version: 01.00A01
User Capacity: 1,500,301,910,016 bytes [1.50 TB]
Sector Size: 512 bytes logical/physical
ATA Version is: 8
ATA Standard is: Exact ATA specification draft version not indicated
Local Time is: Wed May 15 15:13:37 2013 AST
SMART support is: Enabled
General SMART Values:
Offline data collection status: (0x84) Offline data collection activity
was suspended by an interrupting command from host.
been run.
data collection: (33600) seconds.
command.
Self-test supported.
power-saving mode.
Short self-test routine
Extended self-test routine
recommended polling time: ( 383) minutes.
Conveyance self-test routine
recommended polling time: ( 5) minutes.
SCT capabilities: (0x3037) SCT Status supported.
SCT Data Table supported.
1 Raw_Read_Error_Rate 0x002f 200 200 051 Pre-fail Always - 0
3 Spin_Up_Time 0x0027 253 253 021 Pre-fail Always - 5250
4 Start_Stop_Count 0x0032 078 078 000 Old_age Always - 22234
5 Reallocated_Sector_Ct 0x0033 200 200 140 Pre-fail Always - 0
7 Seek_Error_Rate 0x002e 200 200 000 Old_age Always - 0
9 Power_On_Hours 0x0032 085 085 000 Old_age Always - 11574
10 Spin_Retry_Count 0x0032 100 100 000 Old_age Always - 0
11 Calibration_Retry_Count 0x0032 100 253 000 Old_age Always - 0
12 Power_Cycle_Count 0x0032 100 100 000 Old_age Always - 93
192 Power-Off_Retract_Count 0x0032 200 200 000 Old_age Always - 40
193 Load_Cycle_Count 0x0032 139 139 000 Old_age Always - 184450
194 Temperature_Celsius 0x0022 105 098 000 Old_age Always - 45
196 Reallocated_Event_Count 0x0032 200 200 000 Old_age Always - 0
197 Current_Pending_Sector 0x0032 200 200 000 Old_age Always - 0
198 Offline_Uncorrectable 0x0030 200 200 000 Old_age Offline - 0
199 UDMA_CRC_Error_Count 0x0032 200 200 000 Old_age Always - 915472
200 Multi_Zone_Error_Rate 0x0008 200 200 000 Old_age Offline - 0
SMART Error Log Version: 1
No Errors Logged
# 1 Extended offline Interrupted (host reset) 80% 11560 -
# 2 Short offline Completed without error 00% 11556 -
# 3 Short offline Completed without error 00% 11556 -
# 4 Short offline Interrupted (host reset) 90% 11536 -
# 5 Short offline Completed without error 00% 11533 -
# 6 Short offline Completed without error 00% 11509 -
# 7 Extended offline Interrupted (host reset) 90% 11488 -
# 8 Extended offline Interrupted (host reset) 90% 11487 -
# 9 Extended offline Interrupted (host reset) 90% 11486 -
#10 Extended offline Interrupted (host reset) 90% 11485 -
#11 Extended offline Interrupted (host reset) 10% 11485 -
#12 Extended offline Completed without error 00% 11476 -
#13 Short offline Completed without error 00% 11467 -
#14 Short offline Completed without error 00% 11443 -
#15 Short offline Completed without error 00% 11419 -
#16 Short offline Completed without error 00% 11395 -
#17 Extended offline Completed without error 00% 11375 -
#18 Extended offline Completed without error 00% 11369 -
#19 Extended offline Completed without error 00% 11363 -
#20 Extended offline Completed without error 00% 11357 -
#21 Short offline Completed without error 00% 11347 -
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
thanks !
ugen4.3: <JetFlash> at usbus4 (disconnected) umass1 : at uhub4, port4, addr3 (disconnected) (da1:umass-sim1:1:0:0): lost device - 0 outstanding, 1 refs
