Greetings! I'm testing different drive sizes in a Netapp DS14MK2 enclosure and I see that when I put a 3 TB drive in, FreeNAS sees the drive as 801 GB. I've searched the forums and seen that others have had similar issues. What I would like to do is resector the drive into 4096 byte sectors and see if there is some improvement. Can FreeNAS do this or should I boot into ubuntu and run SG utils for this?
Smart Output:
[root@freenas] ~# smartctl -a /dev/da0
smartctl 6.5 2016-05-07 r4318 [FreeBSD 10.3-STABLE amd64] (local build)
Copyright (C) 2002-16, Bruce Allen, Christian Franke, www.smartmontools.org
Vendor: ST3000DM
Product: 001-1CH166 SX
Revision: CC24
User Capacity: 801,502,617,088 bytes [801 GB]
Logical block size: 512 bytes
Rotation Rate: 7200 rpm
Logical Unit id: 0x2208000a339ac67f
Serial number: Z1F3TPA8
Device type: disk
Transport protocol: Fibre channel (FCP-2)
Local Time is: Fri Feb 3 11:35:11 2017 PST
SMART support is: Enabled
Temperature Warning: Disabled or Not Supported
SMART Health Status: OK
Current Drive Temperature: 0 C
Drive Trip Temperature: 0 C
Error Counter logging not supported
[GLTSD (Global Logging Target Save Disable) set. Enable Save with '-S on']
Device does not support Self Test logging
Smart Output:
Vendor: ST3000DM
Revision: CC24
Device type: disk
