Maturola
 - Jun 26, 2014
Not a 100% related with FreeNAS but it is what the case is being use for.
Coworker is having severe thermal issues with the Norco RPC-230, he is running 4 disk 5400rpms and they are overheating, when I check up his box I noticed that his power supply (as mot modern ATX power supply) have the intake fan in the bottom (it may be the top, not sure) and it is being blocked by the case. it seen that the case actually use the PS as main Pusher of air into the case.
This as you may imagine cause lot of heating issues with his supply and the disks.
Have anyone use these case (or similar) and have a power supply recommendation that have Front-to-back Air flow? (Supported supply is standard ATX size)
Thanks
PS: my other idea is to make some holes in the case to let Air in, but we would like to avoid that if at all possible.
Thanks
