I moved 4 drives from a Synology NAS that died into a newly built freenas box but am unable to wipe the drives to create a pool. I get the following error when I run the wipe command
I've searched and found many discussions about with a dozen varieties of dd commands but there doesn't seem to be a definitive solution. Is there any freenas instruction on how to wipe a drive from the shell when using disks that have previously been used? Thanks
[EFAULT] Command dd if=/dev/zero of=/dev/ada2p2 bs=1m count=32 failed (code 1): dd: /dev/ada2p2: Operation not permitted
