Cant Remove Log Device
M@rk
I am trying to remove a log device from my zfs pool. If i do it from the gui it silently exists with no error but doesn't remove the device. if i run "zpool remove pool device" from the command line it just silently exits as well. Anyone have any ideas how i can remove the log device from my pool?
    NAME                                            STATE    READ WRITE CKSUM
    Volume1                                        ONLINE      0    0    0
      raidz1-0                                      ONLINE      0    0    0
        gptid/a9f6ff70-a1cd-11e2-8ffc-003048c1cd6e  ONLINE      0    0    0
        gptid/7715cdc3-96dd-11e2-afe3-003048c1cd6e  ONLINE      0    0    0
        gptid/777b05cb-96dd-11e2-afe3-003048c1cd6e  ONLINE      0    0    0
      raidz1-1                                      ONLINE      0    0    0
        gptid/9bc9e79b-96dd-11e2-afe3-003048c1cd6e  ONLINE      0    0    0
        gptid/9c2c8770-96dd-11e2-afe3-003048c1cd6e  ONLINE      0    0    0
        gptid/9c94ea93-96dd-11e2-afe3-003048c1cd6e  ONLINE      0    0    0
      raidz2-2                                      ONLINE      0    0    0
        gptid/82f4d618-3257-11e3-8935-0025903d38fa  ONLINE      0    0    0
        gptid/84fad697-3257-11e3-8935-0025903d38fa  ONLINE      0    0    0
        gptid/87369104-3257-11e3-8935-0025903d38fa  ONLINE      0    0    0
        gptid/8957b1a0-3257-11e3-8935-0025903d38fa  ONLINE      0    0    0
        gptid/8b597dc6-3257-11e3-8935-0025903d38fa  ONLINE      0    0    0
        gptid/8d5d6721-3257-11e3-8935-0025903d38fa  ONLINE      0    0    0
      raidz2-4                                      ONLINE      0    0    0
        gptid/51c07eef-3e5a-11e3-8e76-0025903d38fa  ONLINE      0    0    0
        gptid/540279b3-3e5a-11e3-8e76-0025903d38fa  ONLINE      0    0    0
        gptid/56413aef-3e5a-11e3-8e76-0025903d38fa  ONLINE      0    0    0
        gptid/58825dd0-3e5a-11e3-8e76-0025903d38fa  ONLINE      0    0    0
        gptid/5ac4fd2a-3e5a-11e3-8e76-0025903d38fa  ONLINE      0    0    0
        gptid/5d0165d5-3e5a-11e3-8e76-0025903d38fa  ONLINE      0    0    0
    logs
      da1                                          ONLINE      0    0    0
M@rk
FreeNAS-9.1.1-RELEASE-x64 (a752d35)
<ATA SAMSUNG HD103UJ 1113>        at scbus0 target 3 lun 0 (da0,pass0)
<ATA Samsung SSD 840 7B0Q>        at scbus0 target 6 lun 0 (da1,pass1)
<ATA SAMSUNG HD103UJ 1113>        at scbus0 target 8 lun 0 (da2,pass2)
<ATA SAMSUNG HD103SJ 0001>        at scbus1 target 1 lun 0 (da3,pass3)
<ATA SAMSUNG HD103SJ 0001>        at scbus1 target 2 lun 0 (da4,pass4)
<ATA SAMSUNG HD103UJ 1113>        at scbus1 target 3 lun 0 (da5,pass5)
<ATA SAMSUNG HD103SJ 0001>        at scbus1 target 4 lun 0 (da6,pass6)
<ATA SAMSUNG HD103UJ 1113>        at scbus1 target 5 lun 0 (da7,pass7)
<ATA SAMSUNG HD103UJ 1113>        at scbus1 target 7 lun 0 (da8,pass8)
<ATA SAMSUNG HD103UJ 1113>        at scbus1 target 12 lun 0 (da9,pass9)
<ATA SAMSUNG HD103SJ 0001>        at scbus1 target 13 lun 0 (da10,pass10)
<ATA WDC WD20EFRX-68A 0A80>        at scbus2 target 0 lun 0 (da11,pass11)
<ATA WDC WD20EFRX-68A 0A80>        at scbus2 target 2 lun 0 (da12,pass12)
<ATA WDC WD20EFRX-68A 0A80>        at scbus2 target 3 lun 0 (da13,pass13)
<ATA WDC WD20EFRX-68A 0A80>        at scbus2 target 4 lun 0 (da14,pass14)
<ATA WDC WD20EFRX-68A 0A80>        at scbus2 target 5 lun 0 (da15,pass15)
<ATA WDC WD20EFRX-68A 0A80>        at scbus2 target 6 lun 0 (da16,pass16)
<ATA SAMSUNG HD103SJ 0001>        at scbus2 target 11 lun 0 (da17,pass17)
<ATA SAMSUNG HD103SJ 0001>        at scbus2 target 12 lun 0 (da18,pass18)
<WDC WD5000BPKT-22PK4T0 01.01A01>  at scbus3 target 0 lun 0 (ada0,pass19)
<Verbatim STORE N GO 5.00>        at scbus9 target 0 lun 0 (da19,pass20)
About a week ago someone had a similar problem. If memory serves me right he did the same thing you did. You added the log device from the CLI and not the GUI. It's obvious because it's not a gptid but rather da1. His only solution was to destroy the pool and recreate it.
M@rk
Only reason it was added via CLI is because I couldn't remove it via the GUI, so I tried removing it from CLI but had to replace it in the end because I just couldn't remove it.
D
dlavigne
Guest
Please create a bug report at bugs.freenas.org and post the issue number here.
