It worked under 9.3 and the first 9.10 releases, but as of
FreeNAS-9.10-STABLE-201604181743 (74ef270)
I can't connect.
AD is a samba4.3 setup.
The GUI forces me to set encryption:
So I can't even save my settings. I didn't have encryption on in the last working months.
Following the troubleshooting from the docs, dns and the first two lines are fine, and then:
I can't connect.
{'desc': 'Strong(er) authentication required', 'info': 'BindSimple: Transport encryption required.'}.
[root@freenas] /# service ix-kerberos start ERROR: option error Traceback (most recent call last): File "/usr/local/libexec/nas/generate_krb5_conf.py", line 557, in <module> main() File "/usr/local/libexec/nas/generate_krb5_conf.py", line 489, in main ad = FreeNAS_ActiveDirectory(flags=FLAGS_DBINIT) File "/usr/local/www/freenasUI/common/freenasldap.py", line 2424, in __init__ super(FreeNAS_ActiveDirectory, self).__init__(**kwargs) File "/usr/local/www/freenasUI/common/freenasldap.py", line 1564, in __init__ self.set_servers() File "/usr/local/www/freenasUI/common/freenasldap.py", line 1720, in set_servers self.dchandle.open() File "/usr/local/www/freenasUI/common/freenasldap.py", line 315, in open if self.ssl == FREENAS_LDAP_USETLS: ValueError: option error
